Ticking noise
odeste
Hi-This is probably a common question and answered here before but I can't find a thread.
I have an '86, 2.3L, EFI, 5 speed Ranger. A relatively new Jasper engine with 4K on it. I did a compression test the other day (I'm a bit obsessive with taking care of it) and a vacuum gauge test (1st time ever). Results: 21-22hg, comp.-190, 185, 195, 190.
It runs great but I keep hearing, at low speed or idle, a slight ticking engine sound reminiscent of valves or lifters from my truck for many years prior to the rebuild. I just starting noticing it recently and am wondering if it's always been there and am just paying attention to it now, or it's a common characteristic of my type of engine. Is it just me as all seems fine?
Any thoughts? Thanks
Could be injectors or maybe an exhaust leak check your manifold bolts. Hope this helps.
Thanks! I thought about the manifold leak but didn't know how to check it. Will research
probably valves, normal, unless it sounds like a diesel it should be fine...
No diesel sound. It sounds smooth and great except when I'm driving with the window down and close to something solid on the driver's side like a guard railing, etc. where the sound kind of funnels back to me. It's just me being a worry wart
If you ever have to take the followers off under the valve cover, pull the lash adjusters out and drop a dime under each one, you'll have an $.80 fix
Thanks but can't do that as it would void the warranty. I have a 3 year, unlimited mileage warranty from Jasper. I just hate dealing with the garage that installed it. But if it worsens at all I guess I'll just have to take it there but , of course, as it usually goes with things like this the sound won't be there when, or if, I take it in.
