NixRanger
Hi all;
Recently got the TK5 tranny rebuilt, also replaced hydraulic cylinders (master and slave) and new clutch assembly. Less than 200 miles later I thought the throwout bearing was defective due to a horrible squealing sound and I replaced it - that was a waste of time and $$, 'cause the noise still present.
The noise happens whenever the clutch is not engaged (clutch pedal is not being pushed down). Doesn't matter if I'm in neutral or in any gear, the noise persists. The noise increases/decreases with corresponding throttle - it doesn't get worse, but it does get louder as RPMs increase - it's this steady sounding annyoing squealing - and it's a royal PITA !! So as I drive in my neighborhoood or in town I "ride the clutch" - I push the clutch pedal in about an inch and the noise stops. I know this ain't good for the TB.
I talked with the outfit that rebuilt the tranny - they're supposed to be a reliable business, which is why I took tranny to them. I'm being told that the squealing sound is due to bad thrust bearing in the engine.
I've never hear of that bearing going bad. The engine has been a reliable one, was rebuilt 80,000 miles ago.
I regularly service it - even maintain a logbook to keep track of stuff done to it.
But I'm stumped by what I'm being told - THRUST BEARING ? ?
you guys have helped me on all sorts of things Ranger, anyone got any ideas on this one ??
