throw out bearings???????
They have a hydraulic slave cylinder, yes.
The release bearing is mounted to the slave
AD
release bearing/ throwout bearing is all the same thing. All manual transmissions have them, it allows the clutch fork to engage the pressure plate without grinding through. The only difference between cable spring and hydraulic is the method used to provide force to the clutch fork.
