swynx
when i replaced my oil pan gasket on the 1994 4.0 i just lifted the engine (no trans) thought i had 1 of the 2 engine mount bolts on, but i was wrong. the engine shifted and tore the throttle cable right where it comes out of the firewall. the cable itself is still good, but the housing is bad, and the wires around it are frayed. its causing the throttle to stay open partly and its sticking.
i tryed trimming the housing and making it work but its not much better. are these rebuildable? could i use like some bicycle brake line or something for the housing?
i also tryed to just remove it but, i couldnt get the black plastic piece out of the firewall with a screw driver or plyers, the do just pry out, and push in?
pull and save is 120 miles away, the local junkyards dont even have it listed.
