Throttle cable replacement?
Oroville
CA - USA
Good evening,
We just got a 1998 Ford Ranger 3.0, 4x4, 5spd manual. I was thinking I had a vacuum leak but upon inspection I found the throttle cable was frayed just inside the shielding and hanging. Tapping pedal sometimes frees it. Anyhow, I'm having the worst time trying to locate a new OEM cable. Found a bunch of the China types but they are all universal.
Does anyone have a link to where to get one? Or are there compatible parts from like 2000+ years?
I'm fine with aftermarket, as long as it's a direct fit. Or is everyone running the universal types?
Thanks
I don’t know, but you may need to have someone make the cable. I’ve never found a cable for sale. It’s probably not hard to make yourself.
I think this guy found a Ford part that kinda works. But even 9 years ago there weren't any throttle cable options that were a direct fit.
I would go searching through some salvage yards
Look at your throttle cable. Tell me how you plan to remove it. I’m almost certain you would have to cut the end off. So… how would you put on the new one? You would have to crimp the ends of a regular cable right?
If there isn’t a presized Motorcraft part available, then I think the only solution is to get a universal cable and cut it to length.
However, I do find the part number and here it is on Ford parts Giant. It says discontinued though.
I also did some quick searching on EBay and they have throttle cables but you’ll have to measure yours to get the right fit.
Throttle cable on EBay
