throttle cable frozen
89rangerfun
So found out yesterday after playing in some snow that it seems my throttle cable is frozen stuck. The pedal wouldn't push in and it obviously wouldn't get any gas. so I popped the hood and looked at everything. It all looks fine no snow or ice built up. I couldn't get the throttle to move at all when I pushed on it or even beat on it with my flashlight. I disconnected the cruise control just to see if it was locking up for some reason and it still wouldn't work. After beating on it and using a few hand warmers to try and get it warmed up I could move the throttle fine but it wouldn't rebound back so if I gave it gas it would sit at 4krpms and not come down. after work I was going to get some antifreeze and squirt it all around and heat it up even more. any other suggestions?
-Tired 2.9 5 speed 4x4
Thaw it out with a blow-dryer then spray with WD-40. Windshield de-icer or Dri-gas.
Yes ^^^^
Reads like the throttle plate and/or cable has some water inside, you need to displace it, as said above you need to get some oil or wd-40 inside to push out or dilute the water.
E-brake cables can do the same thing, same PITA when rear brakes are locked up
I will third what was suggested.
I had the problem of throttle getting stuck full. In my case it was rust, I had let it sit a bit too long. Working it and WD-40 got it moving freely again
