Actually there is a point to the larger TB on 2.9 engines that are run oin '88-92 engine management, but... (and this is a medium sized "but")
The larger TB doesn't do what you think it does....
What it does do is lets a full throttle ammount of air into the engine while you
DO NOT put the pedal against the firewall/floorboard seam
The effect of this is with the throttle NOT 100% the engine management stays in "closed loop" and therefore doesn't go to the 100% throttle default of "CPFR"
CPFR = Completely Pig Fooking Rich
If you are expecting a performance boost from the bigger TB... prepare for disappointment, what the bigger TB does it does at 3/4-7/8" pedal
When I was running a 2.9 I actually added a stop to the throttle to prevent it from ever giving the WOT signal from the TP sensor to the computer.
You could push as hard as you wanted to on the pedal, but the throttle
linkage STOPPED at 7/8.
Frankly this is more of a "mileage mod" than a "performance mod"
Unless you understand exactly how things work, and that is to say how they REALLY work, not just how you happen to "think" they work, you shouldn't be modifying things...
there are reasons I managed to squeek 26mpg out of a 2.9 engine in a Ranger supercab
with 4.10 gears
AD
