RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
Ok, here goes the stumper...
Vehicle - 96 Ranger 4x4 X-cab auto
Problem - The odometer/trip meter works intermitently, but the speedo works perfectly, no skips or jerks. Here is the kicker: truck has been through an engine swap ( motor, trans, tcase [ and different speedo head/driver located in tcase] from the donor truck) has also had the rear axle changed along with the ABS sensor located in the housing. Vehicle speedo is run off of the VSS in the tcase, not the rear axle (from what I have read in the tech library and other threads here on TRS). The odometer problem has been both before and after the engine swap and the axle swap, and I have also swapped out the instrument cluster, still does the same thing. Some times when I drive it, it doesn't move, other times when I drive it, it will operate normally. It doesn't do it on certain days, or when the ignition is turned off. I could go to the post office or my FD, stop, get out and get something with the engine still running, and it won't work going there, but will on the return trip home, or vice versa. Same with turning the engine off, I can make a trip, like to the store, it'll work, on the way back, it won't. I works when it wants to. Only thing I can think of is to change the GEM, which I haven't tried yet. This problem makes it hard to change the oil at regular intervals...Anyone got any clues or answers?? Might be a question for AD
SVT
SVT
