thinking about a lift with long arms
84stealthranger
murphy north carolina
i seen in another thread a lift from national wheel and tire http://www.ntwonline.com/83-97_RANGER_6_SPECIAL_W_SHOC_P12793C198.cfm thanks to 89PBR96 for telling me about it. i was thinking maybe making long arms and what would be the easyest way to make some. i looked at the top where it says read here before posting and seen some long arms but still not too sure about it. and i dont wanna use the blocks that come with the kit what r my options on lifting with other springs?
You can use the blocks for the rear still and buy a set of Chevy rear leaf springs for more flex.
is that the 63'' swap how safe are them blocks for off road use
Yep I off road my truck and I'm using the factory blocks plus my lift blocks no Problems I would rather only use the lift blocks but I need to ad a leaf or do the chevy swap to keep it level
I don't have any Ideas I even searched and found nothing I'm sure someone will chime in and help you out man.
2" DOM tube (1020) is ideal for making extended radius arms (and is what I used for mine). Some here have used 2" sq. tube as well. Whatever you use, just make sure it has at least a .250" wall thickness.
