lilred96
I was going to the store and before i left to go inside the store i heard a wierd bubling sound so i went inside cameback out i looked under the truck and i was leaking alot of coolant. i opened the hood and saw the overflow resivior ballooning and a 2 ft spary of coolant comming out of the pin hole on the lid i threw a rag on it and it was boiling. i waited till it stopped i opened the lid it was filled to the brim the longer i waited the cooler it got and the rad sucked the coolant back in-was the thermostat stuck closed? -the temp gauge wasnt on hot yet 3/4 or middle on the gauge. after it cooled i took the short way home prepaired to stop if it was getting to hot it made it fine. and i can still drive around with ac on-no overheating i gues it unstuck itself? Now the temp gauge fluctuates more than usual. Im sure its the thermostat going out right? truck runs great my head gaskets are fine. allways the correct amount of coolant has anyone else experienced this? how much is the motorcraft one are they easy to install?
