Can't find anything in the search... 94 4.0l, yesterday morning (didn't notice on friday) the temp gauge decided to act weird. I let the truck warm up for a good 10 minutes, which usually gets it just below running temperature, even on a freezing day (which it wasn't).
Noticed a few minutes down the road I was still cold, but the heater was blasting as usual. Then intermittently, the gauge would read cold, normal, a touch above normal, back to cold, back to above, cold, normal... Heat didn't change, and the truck ran the same.
I'm thinking thermostat or the sending unit or whatever it is that controls the gauge. Although thermostat would make it run HOT because it's stuck closed? Or not heat up at all being stuck open?
