 - Nov 8, 2007
 - Manual
So I think I may have installed my thermostat upside down?
I positioned the tiny bypass hole at the bottom, but looking around TRS, it looks like it should be at the top acting as an air vent?
I know I should have paid more attention when removing it, but I was more concerned with the 2ea stripped out thermostat housing bolt holes from the previous owner. Luckily I was able to use longer bolts to reach good threads and get a good bite.
Plus if I did intsall this upside down could it be to blame for my overheating issues?
I replaced my single core radiator with my extra dual core one from an auto tranny, checked the thermostat, and put new fluid in hoping to solve the issue of it running around 225* in town driving, at which I turn the heater on full to keep it from going hotter.
I had to remove my fan shroud due to the radiator being thicker and my bodylift offsetting the alignment some, and I will be replacing the fan soon, due to cracks showing.
What would be the most likely cause of running hot at slow speeds?
Thanks, Fordtough
Thanks, Fordtough
