the slo-vo build thread...
it aint too bad...figured they'd all break so im happy with just 2 top bolts
I can send ya a pic of the harley jig, I think? Basically ya bolt it to the corresponding blot on the same port, swing it around and then drill away! Keeps 'er straight and aligned. Used 'em several time with bikes in the frame. Sure ya could fab up something with some plate, a drill press and a bolt!
Grind off stud flush, bolt jig in corresponding bolt hole or onto stud, wing around and tighten down, put bit thru hole, drill away! Oh, if ya notice the back of it has a raised porotion that protrudes into the exhaust port to keep 'er aligned!!!
ill figure it out...hopefully they will come out easy
You put your hand (the adjustable wrench) and torqued it too hard jon-boy.
Frank
Ain't it just wonderful that when all of us have these projects going on we can count on each other to give us some helpful advice or remedies and also push dem buttons as hard as we can on each other! Knowing that when we do finally meet each other on the trail, we'll help each other out if need be and get along just fine, even when you guys are ribbin me for not being able to drive my "thank you very much RangerSVT for the SAS rig" as good as I should be able to since I'm outa practice!
:shok:
don't worry....i'll be right in front of all of yun's with my trusty little truck to pull ya'll to safe high and dry spot.....:D
btw, i have some aftermarket extended RA mounts to go on the frame for the swap if ya need em'....
l8r, John
Is that after ya get done peelin all the bark off the trees to make the trail wider for us, or sucking the lake level down so it's not so deep? Ya sure it was the water, maybe ya sucked a crappie or bass in there. New fishing method?
:icon_confused:
I bet ya never ordered the wrong ring & pinion though.
:shok::icon_surprised:
im just ready to start hitting some harder trails...im getting the itchies to get in the rocks bad
well, get those axles in the Ranger for Sat......i'll take ya on some harder trails....
l8r, John
Jon, what did the expo RTI? Just checkin in on the ole girl! And I thought you were a mad man for driving that far, but the suspension swap is a whole new level!
Craig
lol she didnt do so well...with the super stiff TTB spings it made a 615...
once i get the lift setup under the ranger i will be going to xj or EB springs to actually get some flex
im not crazy :D hell yall should be proud of me for actually de-modding a vehicle...im pretty bad about keeping my DD's...well DD's lol
the expo is doing god, but the mpg's are killing me...and also figured out this week im gunna have to change the heater core before long
Good luck! Glad to see her in good hands!
PS Jeep is coming along nicely too...I know, I know its the TRS
CW
lol yea she may down the road get lifted again but for now...stock is what i need
good to hear, hell there are alot of non rbv builds on here...another couldnt hurt!
oh yea i also got the TC shifter in
Moving right along, glad someone is. Did score a 8.8 31 spline for my rear! And a exploder center console and some of them fancy exploder visors with the vanity light to admire myself in the dark.:yahoo::yahoo:
Still huntin the DANA 44.:bawling::bawling:
