The Return To Wellsville 2013 (10/05/13) - Official
I have 2 sets of leafs if you need to borrow them.
I literally gave a set of perfect 64s away last spring.lol
They are under an Amish man's hay wagon now.lol
Sent from my XT907 using Tapatalk 2
i am good. i will just spend the whole day sunday making sure i get them out of a 1500. pick n pull has 7 1500s down there lol. and luckily i work in a shop so i will probably slowly tear into my truck all week and weekend. hope they dont mind! lol
Question , my 97 has a 2 inch lift and very agressive 31's with a L/S rear , will that be ok , or does it not stand a chance ?
Sampson's b3000 always did fine. He was on 31s as well and doesn't have an l/s. Might have a bit of trouble keeping up with the built rigs. The last trip I was on we split up into a big rig group and a smaller truck group. So far no smaller trucks seem to be going though.
you will be fine. i used to run my 31 m/ts out there with open front and rear. also depends on the driver too. but if there is anything too bad we can pull you thro pretty much whatever.
it helps that pat can drive well. he knows his truck very well.
You'll be fine.
The important part is that everyone has tow hooks (or d-rings) to hook to in case they get stuck.
True.
If we can get a couple of smaller more stock-sized trucks going I could maybe convince pat to come. Then me and the other two non-built trucks. That'd be four.
In the past, it was common to have more than one group based on vehicle setups.
mine is pretty much stock. 2" lift on 31s. pat and i wheeled together at the spring run in bundy hill. it was fun. he can go pretty much anywhere i can go.
I texted him but he didn't respond.. When I talked to him last he said probably not because he didn't want to be the smallest truck.
