The Long Link Question
broncc
Ham Radio Operator
N/A
MA - USA
Vehicle
Ford Bronco II
Drive
5"
Giving my truck more money than it deserves.
I have a Bronco II with d28 (very soon to be d35) front suspension. Currently it has a 4" Rough Country on it. Combine this with my 31" tires and I rub when I turn. In this thread I intend to focus on getting the sway bar out of the way. The kit just drops the stock frame mounts down 4" and keeps the bar in harms way of the tire. I did a quick search of the internet and this forum but I haven't been able to find anyone who sells longer sway bar links.
Does anyone know of some options I have? Maybe another link from a different car that swaps over? I don't think my welding skills are ready for suspension work yet.
Welcome to the club.
Check out ones for a Jeep Wrangler, I know some of those fit (a friend of mine has end links made for a Wrangler JK on his Explorer). One or more of YJ, TJ and possibly CJ links may fit also.
If you're looking for disconnect-type links, beware some JK ones won't work on the Ford axle (Rubicon Express for example, they use single-shear mounting pins with hitch clips and are made to simply slip off and be removed, whereas Ford has the links mounted in double-shear at the axle). Because of this you need links that disconnect in the middle.
