- May 28, 2011
Many times I have seen threads on here asking about what clutch kit to install in your Ranger. Well here are some photos of the LUK RepSet that I just unpacked to install in my build. I have compared it to the cheap replacement clutch that came out.
Ok... So the pressure plate wasn't yellow when I unpacked it.(engine paint works wonders) But as you will see in the following photo comparing the pressure plates what happens to bare metal in a very short time in my climate.
As you can plainly see the LUK (painted yellow) has more metal where it counts in the pressure plate frame. The LUK plate is also notably heavier when you pick it up compared to the cheesy plate.
Again with the Friction Plate.. You can easily see the quality difference. Meatier frame and springs plus heavier rivets and webbing make for an all around stronger product. Also notice the cheese plate has three rivets holding the hub spring assembly in place and the LUK has four.
I didn't take a picture of the cracked metal in the hub web of the cheese plate but next time I take the camera out to the garage I'll snap one and upload it. I hope that many of you will find this post useful in helping whether or not to purchase a quality clutch or cheese.
LUK in no way sponsored this blatant propaganda. I simply don't want to see any of you guys crying by the trail.
