The chirp is back....
Eddo Rogue
Burbank,CA
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I think my cam synchro is chirping again. I've already replaced it twice. The current one is a NOS discontinued Motorcraft unit I snagged off ebay.
I am hoping its just a pulley, but it is intermittent, so I dont think running it without the belt will help diagnose.
could it be just a pulley? An Idler, or my crappy ac compressor perhaps?
Why would my cam synchro keep going bad? The first one I get because it was Dorman unit. But I thought the Motorcraft would last.
Yes Virginia, I soaked the gear in oil before assembly.
So yea, this is a thing...
Try squirting penetrating oil on one pulley bearing at a time then drive for a day; again one at a time; if chirp goes away thats the one. What belt does it have on it?
You can run the engine for a little while when it’s cold without a belt and not have a problem. Unless you have to have the engine warm for it to happen.
Just don’t do it for more than a few minutes. Once the coolant in the block starts getting hot, it’s time to shut it down before you over heat it.
Yep it only does it when it's warm...usually after a hard drive like a freeway run when traffic flow is 80mph
Well that kills that idea...
