Been a rough couple of weeks lately but I've finally gotten around to swapping from RBV coils to EB coils. All in all, swap was no problem but it was the fine tuning that has been the biggest pain. I've snapped a few pix along the way to help document the swap, as well as give some before and after poses. Also to show some of the headaches that I've encountered. I'd appreciate if people like Junkie and CopyKat would chime in to give pointers as to what they done when they swapped to a softer coil.
For those that don't have any background, I started with a 91 Ex with a 6" JD lift. This is the before pic. the day I got the lift on.
Ride and drive is excellent. Flex is ok.
From what I understand RBV coils are in the 475lb/in range. I wanted to swap to an EB coil that was softer to get more flex. I have the new JD coil buckets that allow you to run either RBV coils or EB coils so I figured the swap would go without a hitch. Yeah, that was my mistake....
Started out simple enough. Unbolt the RBV coil.
Bolt on the lower retainer that I made up. Be sure to not strip out the 3/4" threads in the axle housing as it takes forever to find a 3/4" tap and fix them back. Don't ask how I know, but I didn't drive for a few days.
Then slap the EB coil in.
On a side note, when swapping to a MUCH softer coil, static height means nothing. I started out with a new stock EB coil. After I put it in and got the EX off the jackstands it sit approx. 2 1/2" lower in the front and made my tires go / \. Yeah so I had to swap them back out.
I ended up going back to JD and talking to them about spring rates and taking many measurements. We finally decided that I should go with their 3.5" lift EB coil with a rating of 225lbs/in. This spring is 23" long static. I thought we'd never get it in but we finally managed to get it in and back on all fours. At the same time, we installed a spool in the rear. This is how it sits now.
It's approx 1" taller in the front now than in the first pic. Here's a close up of the coils in their new home.
Now we come to the point where I'm having some problems...
As with the RBV coils, the ride is excellent. Since these are a progerssive rate coil, they are mostly squished down under the weight of the Ex, but they still soak up bumps great. However, my biggest complaint is taking off from a red light. Since the coils are so light and compressed under the Ex when I take off from a dead stop the front end raises up, no joke, at least 8". It's to the point where my tires are only touching on the outer edges of the tread and look like this \ /. It stays that way through first and second gear and when I hit drive it begins to settle down back to normal. The first time I took off and it done it I about crapped my pants. Now since I have the rear spooled and the front end is doing this, turning at the red light is a sight to say the least. The front end raises up and I can't hardly turn either cuz I'm riding on the outside edge of the tire. I'm going to put limit straps on it to keep the front end from raising more than 1" above ride height.
This is from where I was parked in JD's parking lot and moved over to their shop door (approx. 25' in a straight line without gassing it)
Here's what the front end looks like up close.
So I dunno, other than putting limit straps on it, I'm stuck. The coils ride good and I'll find out this weekend how good they flex, but they are in no shape to drive on the street in the current situation. I'll be running these coils also when we do the SAS swap in the near future.
