TomJenks
Hello to all.
Got some bad news on the ranger last nite.
Had a coolant leak that started last week. Went to check it out and an hour later I found it was the freeze plug on the passenger head.
I figured i would replace it(freeze plug), then I got to thinking about just swapping in another 4.0L OHV instead.
The main cause of all of this is because of rusty coolant. So, my reasoning for replacement is that I'm sure the other freeze plugs are not too far behind this one.
I got the truck as a beater/3rd vehicle with 4wd and a 5spd for $600 so I figure I can spend a little money on it.
Now, which would be the best year to look at for a replacement( the truck is a '92 btw)?
I can live with switching some parts(intake/exhaust manifolds, etc.) although I would rather stay away from long block disassembly if I can.
Any info from some with experience/advice with this would be greatly appreciated. Or if someone could point me to a good resource on the topic that would be great also.
