The $600 1988 Ranger project. A semi-serious race truck build.
Radiator? Check.
Big motor needs a big radiator. This one fits that description. It's a 1994 F250 diesel radiator. I chose it because it is big and has a lot of brackets on it that I can use to mount it and to mount fans.
It will probably be flipped over where the hose connections are on the bottom side.
Radiator? Check.
I tried a bunch of different rads when I was chasing a cooling problem. What I learnt is that the bottom of the rad needs support if you plan on jumping the truck. Two of the rads showed definite signs of being bowed and they were mounted using the stock side frames. The final iteration was similar to yours, being mounted in the back, but vertical and on top of a crossmember. I don't believe you plan on doing jumps, just a heads up for any following this thread.
Haha, yeah no jumps.
Been thinking about what efi system to use in this thing and I think I have finally decided on using a Holley Terminator X. I considered using some sort of a Megasquirt variant, like a MS3 Gold Lite from EFi Source or something similar. The Gold Lite looks like a nice piece and would likely be an excellent choice for a plug-n-play setup. However, this is no where near a plug-n-play situation. The Terminator X kit includes a lot of features that would be add-ons to the Gold Lite. Built-in wideband, wiring harness, and touch screen are the most notable features, but probably the best is the ability of the TermX to use a Holley or MSD dual sync distributor for crank and cam positions. The Gold Lite would require me to fabricate position sensors to fill these roles.
The other feature that is very appealing is the overwhelming popularity of Holley EFI. At any event, there are plenty of people that know the system inside and out and can provide tuning or technical assistance if necessary. They are currently on sale, so I might pick one up through Speedway Motors. Speedway gives you points toward future purchases so I can use those points to save even more money on a dual sync distributor. Whoo hoo.
Wow I downloaded the Terminator X app to my phone. Holley is really doing things right. Being able to adjust things right off the phone via Bluetooth is super helpful. That's one of the reasons I always liked my Megasquirts... That is, until MSDroid stopped being updated.
It's going to be nice using an EFI system that is drag race oriented out of the box and operates in terminology that is easily understood. FYI I bought a Terminator X Universal for Ford (PN: 550-937) .
I actually worked on the truck yesterday. haha. I welded the front brake line tabs to the front clip. I tried to make a video but ended up with mic problems and terrible video angles so I scrapped it.
Lately I have been working on my son's '69 Galaxie trying to tie up a few loose ends (exhaust, E4OD trans controller wiring and setup) before we take it on Rocky Mountain Race Week in June. Trying to get some miles on it and get any potential bugs worked out.
My first car was a 68 galaxy 500. Beautiful car until the frame broke by the rear axle. Found out that was a known issue for 68 and 69....
  • Like
Reactions: BBR
This one is far from beautiful but Judd sure likes it.
Started looking at turbo mounting.
I modified the driver's side turbo mount so that the 1/2" flange mounts to the inside, just like the passenger side does. The fact that they were different was driving me nuts. Haha.
I'm kinda dragging on this thing. Not thinking as far ahead as I normally do. I got out to the shop with no idea what I need to get done. Gotta get back on top of it! The winter doldrums!
Took a break from the Galaxie to do a little work on the Ranger. I started making and installing sheet metal pieces to close up the holes in the cab floor.
Closing up the holes part 2 and I'm still not done!
I built a new crossmember to replace the un-used radius arm crossmember.
Decided to go with manual brakes. I will change if they seem insufficient.
Had to make a block off plate and add a pin higher on the brake pedal for the Ranger manual m/c to fit.
Sure frees up a lot of room.
