The $600 1988 Ranger project. A semi-serious race truck build.
I was rummaging through my garage on New Year's and stumbled upon a set of three-way Summit drag shocks that were originally on the original big block Ranger. Low miles. Haha.
So I decided to stick them on here, at least temporarily. I also stuck a stock wheel on just so I can put this thing on the ground.
Stock, the outside of the tire to the frame rail is 15". Now it's 11.5"
Also started looking at the driveshaft. Thinking abou using a two-piece driveshaft. I have the original front section from the Nanner pickup and it is a beefy unit that will darn near bolt in. A one piece would need to be in the neighborhood of 67" c-to-c. Yowza.
Been waiting on a couple of things so I decided to close up the holes in the cab.
Also, Jesse Fox with 3G video (Youtube) and his buddy broke down in Amarillo while driving Route 66. I went and hung out with them and talked cars while they were waiting for a replacement vehicle to arrive. He will be doing a video series of their adventure.
Whoo hoo the rear tires just showed up. They are just the cheapest 275/60-15's I could find. I will get all 4 tires mounted and balanced tomorrow. Can't wait!
The brake hoses also arrived. Almost time to make some brake lines. Can't wait to try out the new brake line tool!
Slipped one on the front, installed the new spring, put the caliper on upside down. Haha.
Pretty close to the fender, but it's a tiny bit lower than I intend right now. Dang I like these. Haha.
noice.
  • Like
Reactions: BBR
you are from back in the day...big block?
pretty sure i met you very briefly in grand bend ... we were checking out the lutz car amongst others and you had one of the few big dog fox rigs iirc...i remember it being darker but hard to tell from the video...
we were picking up some wpt components and were able to sneak over to the event for a few hours...
hoping to do a rocky mountain race week as well.
  • Like
Reactions: BBR
Yep, I've been around a while. That Fox has had it's share of engine combos. Couple of different big blocks, a n/a 302/T5, nitrous 302/T5, blow thru turbo 302/T5, efi turbo 302/T5, efi turbo 302/AOD, back to a really mild big block, and then the current big block. Haha.
I can't seem to keep my hands off it.
RMRW is loads of fun. I like the format better than Drag Week because you get to be at the tracks longer and you are not under the gun to "one and done" and hit the road.
If nothing, sign up for Road Week and come along for the week and see what it's all about. Lifetime memories.
Pic is from 2023, when it had a big block more suited for towing than racing. Haha. Did good burnouts though.
Front track width is still being a bit troublesome. I have 1" narrower lower control arms in it, but I feel like they still need to be shorter. Or..... I could pull the lower control arm pivots on the subframe in 3/4 to 1". The only trouble with that would be the possibility of running out of camber adjustment up top. I need to take some good measurements and figure out if that is feasible.
Ok, I actually just went out and took some measurements. With that camber adjustment maxed out, I am currently at 2 degrees of neg camber. Some quick CAD modelling and math show that I can move the lower control arm pivots in 0.82" and be at 0 degrees of camber. This might be the route I choose. I would rather alter the frame a little and use off-the-shelf arms than doing the opposite. Luckily, the pivot tabs on the frame are quite widely spaced, so that gives me room to come up with a workable solution.
Of course, this is not unexpected with a pre-production frame and this is something I have been thinking about in the back of my mind for a while . I am literally the first guy to jam one in a Ranger so hurdles are expected.
definitely the way to go. off the shelf arms are ideal. stuff you know may need replaced after a bad bounce and tag.
