Demersus
- Feb 13, 2011
- 2.9 V6
- Automatic
Hi all,
Just finished installing a rebuilt 2.9L in my 1990 Ranger Custom. Had to troubleshoot a no-start situation. Went through everything and narrowed it down to a fuel delivery issue. EEC, relays, fuel pump/pressure, spark and compression all look good. I even did the electrical pulse test on the fuel injector connectors and all seems normal. So I pulled the fuel rail and injectors to inspect and test them. When I do a direct 12V test on them individually, I cannot really hear or feel the solenoid clicking. I think I can hear a very faint clicking in some of them, however. I've swapped polarity as well with no noticeable difference.
Is this a valid way to test an injector? Should I expect a fairly audible and obvious "clicking" when I energize one with direct 12V?
I also measured resistance across each, and they fall within 14.5 - 15 ohms. That sounds low, but they're all in the same range. The rig ran prior to the overhaul, so it's strange that all six would fail. So it makes me feel like I'm not testing them properly.
What has your experience been with similar issues?
