kenwheeler
I'm fixing to drop the FM145 trans in my 87 2.9 ext cab 4x4. I replaced the trans but didn't replace the slave cylinder. After (much) bleeding, I never could get any pedal. I replaced everything else. Flywheel turned down, new clutch, pressure plate, throwout bearing, new master cylinder and about 4 bottles of DOT 3. I'm thinking the only thing left is the slave cylinder.
After I take out the old slave cylinder, is there a way I can check or test it to confirm that it was bad?
