Terminal pin size for connectors?
jballard81
Terminal Procrastinater
North Carolina
So in a previous post I broke the door jamb switch pigtail. I was searching for replacement connector pins (is terminal pin the correct word?)
I got to thinking about the other connections that I will likely break in the future and was curious if there's a good list anywhere of all (or some) of the different type of connector pins used in the ranger?
I have the manuals, but I haven't dug through them to see if there is any kind information to that detail.
If not, I will start capturing what I find.
Cheers!
Well, I butchered this one up pretty bad but it measures around 1.3mm.
So I'm going to get a kit that has 1, 1.5 and 2mm terminal pins to see if I can repair it
Good luck. Some things are available, but most of them are customized for Ford.
