- Jun 18, 2024
- Logan, UT
- 2.9 V6
- Manual
My right rear taillight is out. The running lights work but the brake and turn signal are out. Swapped connector and bulb and that is not the problem. Also tested for power at the connector and there is power. This means it is the ground, right? If so, why would the running light still work then? They share a ground.
