Dave
1992 with 3.0L....The temperature gauge does not work correctly.
I did the usual quick test: pull the wire off the sending unit and ground....gauge should read off scale high.....if it does, then most likely the sending unit is bad.
Well I did all that and the gauge did read off scale high, put in a new sending unit, and the gauge still acts the same way. Now what?? Thanks.
Dave
Dave
