Vanner1993
I have been getting worse fuel mileage than my van, along with failing inspection at idle. Ran codes, Temp sensor out of range. I just replaced it when I did the heads so it is brand new. But the computer still thinks it is bad. What else can cause this? Is there a test I can do to see if there is a short? I was told it can be in the processor, can it? I have a machine at shop that shows exhaust gases, above 1000rpm the hc's are in range of 220, at idle about 800 rpm the hc's jump to over 1000. It does not run rich when high idle, only at normal idle.
