If it is the cats I want to be sure due to cost.
If your cats are plugged , it would probably run like crap and may even get so hot the cat would glow.
Driveway should be enough. All you need to do is let the air have a high point to escape from, best place is the radiator cap. Just the temp selector, no need to run the blower. Yes, radiator cap, sorry.
Should I be concerned that the coolant resevoir (the one by the windshield washer fluid) is close to full (way past the "fill to here" line)
If my cats were the issue, wouldnt the temp gauge stay pegged in he red?
So I did this until coolant came out of the radiator. Coolant came out for maybe 15-20 sec then stopped. There were bubbles in the coolant if that matters. Added coolant but was not sure how much to add. Can you add to much? If so, what happens? I installed a new radiator cap.
Also something I forgot to mention is that I hear a burble-like noise when the heat is on. Is that normal? I think it has always done that. Is that just coolant going through the heater?
