Hardwareman
Well I decided to start tearing into the electrical mystery I'm having and after watching "Americas Most Wanted" with the old lady I decided to go out to the garage for a few hours and start digging in.
I bought two entire new cables that go from "the starter to the battery" and from "the alternator to the switch". They both looked pretty hashed and are original. Battery one was corroded bad and the alternator one only had about 10 strands left at the fusable link. Wires snapped like a dry branch when I bent it too!
I also decided to rip out my wiring harness to give it a thorough inspection because I'm tired of this problem and just want to make sure it's gone! I was going to try and use the 2.5 wiring harness I have but it's a little different from the 2.3 I found out. I guess on 98 and above there's no VSS sensor in the harness like the 95-97 model years. There's also no plug for the temp gauge.......wierd. It must be the second sensor on the water tube on the 2.5's but I'm not really sure.
Anyways, enough of my whining. Just wish me luck guys, and if you need pics of anything just let me know. Later.
Allen
Allen
