Dirtman
Former Middleweight Moss Fighting Champion
- May 28, 2018
- 41N 75W
- 2.3 (4 Cylinder)
- Automatic
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
When hell froze over last week I had an issue filling up my truck, the pump kept shutting off way before it was completely full. I just ignored it since it was -15 and assumed ice or something blocked up the filler vent line.
Now its still doing it so obviously there's a real problem I cant blame on the weather. I've tried different gas stations but every time I go to fill it clicks off at almost exactly 70% full and then requires continuous resetting to get anymore fuel in. No CEL so no evap codes. The purge valve is coming on normally and vapor pressure reads good.
Im still assuming just a clogged filler vent line and plan to take it off this weekend to check/clean it but is there anything else I should check while I'm at it?
