Just curious. Who has the tallest lift on this forum and what all did you do to make it?
I'm wanting to find some different approaches. I'm looking at 44s, with Dana 80's front and rear cut up. Linked suspensions with coils front and rear.
I have no problems fabricating but I'm wondering what works and doesn't break all the time.
Thanks!
To me it will still be a show and go truck. If I have the notion of going off road, then I'll have the ability to do so.
I actually want it to participate it in parades and travel from my home to shows nearby, soooo. If I wasn't going to do that then why not stick with my current build?
44's would snap Dana 30's like a toothpick. Same with a Ford 8.8 and 9 inch. The 650hp Ford 331 would make short order of most smaller axles. Why not use the Dana 80's, which by the way are in huge abundant supply from Dodge to Fords. I found a set for $700 complete.
The whole idea behind this thread was to get some ideas about going big, safely and with some ideas about cost cutters. A Ranger can look cool wearing 44's for shoes but it can be functional as well.
how many guys that responded have trucks that run 44 inch tires?
you should carefully note that before cranking your sensitivity up.
i have a daily driver truck and it has run 44's. still can if i want t use them. of course to sensibly accomplish that goal i cut the fenders and run as little lift as possible...this unfortunately limits travel as well. my truck dont look cool though...it frightens most people.
so to have travel and to leave the fenders uncut the answer is obvious.
great advice here already a few posts back. for axles the 1st choice should be rockwells. they will by far be the most cost effective solution. easy to find 700-1500 for a matched set. start looking.
building dana 80's is a bad idea all around. not cost effective by any stretch in comparison....rockwells have huge aftermarket support.
for the purposes you report, dana 44 8 lug and a dana 60 rear full float would work perfectly. stock 4.1 gears....real cheap to do.
suspension is another matter......
some easy range would be a minimal drop sub-frame and leaf springs. very easy to do.
you want links....also easy to do at this scale. start with some of the common 4 link calculators online and work from there.
the pic posted here from the earlier poster is a great start to your ends imo.....he hit it right on the head for ya.
thats how to build a show truck.
it is real simple.
all you need is a shit ton of
MONEY to burn so you can go parading around as the occasions hit the calender. this example looks real reasonable on costs at that. we have 4-5 parades here per year and its a great way to support local issues and charities so i can see the goals as legit for sure.
conversely .... as a guy who also occasionally builds engines...specializing in fuel injecting windsors of all types and drives a ranger with 44 inch tires bitchslapping dana 60 parts into oblivion
and
went thru your past 70 posts these past years...simply because i was perplexed to say the least at the engine choice.
while mostly for sale stuff in the posts....i certainly had pause at, 6 months wiring, and...... how to measure or install hoodpins. paraphrasing of course.
i sure was curious why an engine builder would build a baby sbf for something like this. a 351....stroked maximally...yes. but a 331???
had you listed an exotic block like you picked apart the standard axle selection i would not have looked into the past posts....bit i was curious...
your choice of engine became understandable with the hoodpin question.
i do think for show purposes i would run a big block of some flavor. whatever the best deal was for a good running system...440 mopar, 460 ford, or a 454...fanblade to transfer case.
honest advice,
