Tach does not function?
ncsdaonex
I did the ford explorer gauge cluster swap so my ranger has a tachometer. Everything functions properly except the tachometer. I think a wire was cut or something. Is there any way i can run a wire from the tach service connector under the hood to the guage cluster, if so i need wiring specs and also how many volts should be coming off the tach service connector wire?
I have a 1990 ranger 2wd 2.3L 4 cylinder 5 speed
