T-case question
soylent_green
I have a 2000 4.0 manual.
What transfer case do I have?
What other models have the same case?
You have a (Borg-Warner) BW-1354.
Any RBV made after 1991 will have the same case. However, in 1998 and up Rangers and 1995 and up Explorers they changed the front output from a u-joint to a dish looking thing that uses a CV joint.
Is the front output something that can be easily swapped if I don't find the newer style?
it should i had to change the rear one to a universal when i replaced my 1354e to a 1350 manual. the only thing holding them on is a single 30mm nut a good impact should have no prob knockin it off
