T-bar Help??
dmanmccann
foothills, NC
I have been outside trying to crank them..The ranger was jacked up 3 inches from the ground. I sprayed WD-40 and deep creep on the bolt, they want budge?? Should i try some leverage (pipe) or an air ratchet?? Can somone post a pic of the bolt JUST IN CASE IM NOT TRYING THE RIGHT ONE!
YEah thats the bolt i TRIED to turn..NO LUCK...Can i use an impact wrench or some leverage like a pipe???? I just wouldnt budge at all on both sides
you can use a large two tooth puller to compress the key, that will take the pressure off of the bolts and let you turn them. also you can use a pipe but not an impact. just be careful not to strip the bolt heads so turn really slow. hopfully that will work.
