T-5 clutch disengagement?
kevinbmx77
Does the piece the cable would usually connect to move towards the front of the vehicle or back to disengage the clutch?
(The part the red arrow is pointing at)
Sent from my SM-G920P using Tapatalk
Anyone? I'm trying to convert it to a hydraulic clutch and have to know
To the rear to engage.
Dave
It depends on what the t-5 is out of. The 5.0 the cable moves the clutch fork forward to disengage the clutch. The 2.3 had a second cable that was an inch long to make the cable pull the fork to the back of the car.
Sent from my LGL31L using Tapatalk
Its a 5.0 t-5, thank you. My slave setup should work then
Might have to re-drill the rear hole to align it better
I think I would consider a 1" standoff block to get the line-up better.
Big Jim
