I had a similiar problem when I lowerd my 97. The bracket wouldnt line up on the bottom and sit flat on the front, I took the die grinder and took out the metal I needed on both sides and it works fine. It is a bitch when a bolt on kit doesnt fit quite right and nobody else has had the same problem as you, I know where you are coming from.
