sway bar or not to sway bar
stegomon
auburn/minot maine
88 bronco 2 with a JD front lift and locked 35 swapped in. in the last 2 trucks i have run this lift and front end in i have nut run a sway bar. but every one i ask say to do. so that gets me thinking. how can i run a sway bar with long links....or do you think i should just ditch it. oh and this will mostly be a mall crawler or snow rig:icon_welder:
Ditch it. I've never kept the sway bars on any vehicle i've ever owned...
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Eh, if you don't really wheel it, keep it. But it also won't be terrible without. Just a dash of highway sway. Ttb suspensions don't rely on it that much anyway.
I would remove mine if I had a 4×4.
If its main use is on the street, keep it, put a set of quick disconnect pins in there and pull them when you go offroad.
