sway bar end link installation
tcbradbury98
I am replacing my sway bar end links. Anyone done this and had trouble fitting the new link on? I can't get any more room out of the lower control arm. Thanks
i do them like this. remove both sides of the endlinks. you may need to jack up on the x-member alittle for some extra space and put both links in and tighten them together both installed. if one is attached still and your trying to do the other you may not have enough room to slide the center parts in.
