LittleRangerCB
- Apr 11, 2010
- Automatic
Hey everyone, tried a search but didn't find what I was looking for.
My truck is a 1995 Ford Ranger XL Standard cab s/b. It has the 2.3l 4cyl engine and is 4wd. It is the stock ride height w/ the factory 2 inch lift blocks in the rear.
I want to order sway bar bushings for the front and rear. The problem is I'm not really sure on the sizes.
I took a micrometer yesterday and measured the thickness of each bar. The front was .905-.915" depending on where I measured it. The bushings on the frame brackets dropped the bar down 2" from the centerline of the bar. The rear bar measured .611-.630" depending on where I measured it.
What size do I need for front and rear?
TIA
-Marc
TIA
-Marc
