swapping in a d35
4x4truck_stop
washington
I broke the outer shaft on my d28, im going to pull n save this week to get a d35. I have a 4 inch suspension lift, would you recommend extending my radius arms when I do the swap?
If you are looking for some better flex, I reccomend exteneded radius arms.
Are you planning on building some?
Yes I would be using the existing radius arm, cutting it in half and adding tubing. About how long should i extend the arms?
12-15" extended is a good amount.
