9798ranger
What will I need to do for this to work. I was told by a friend on FB that I can just switch the motor and wire harness and be done. If anyone could give me insight on this it would be much appreciated. Also the truck I am putting the 2.5 in has the 5r55e. The truck the 2.5 is comming out of has a 4r44e wich will be getting sold or I will rebuild. Do I use the same torque converter that is on the 55r to conect up to the 2.5? And do I keep the flex plate on 2.5 or swap. ( will be replaceing rear main/oil pan seals. Thanks ahead of time!!!
