I’m writing a paper for my technical communications class, and part of the paper requires a professional opinion. The paper is about the pros and cons of independent and solid axle suspension systems. So my question to you guys is just that what are the pros and cons of each system, what are their weak points, how can those weak points be improved, and where does each type of suspension system work best?
thanks in advance
thanks in advance
