suspension help
1985Ranger124
Penngrove, California
Ok, so I was wondering if anyone has done a solid front axle swap with full size axles from a early 70's f150. I would like to know how to do the coil buckets. They need to be moved out pretty far from what i can see. Or could I just run only coilovers.
so a dana 44 full width? Plenty of threads on here about a full width dana 44.
i have not seen any that had details on how to do the shock tower
You're not going to get spoon fed. If you're taking on a project like a SAS, you should be able to figure out shock towers on your own.
Search, this has been gone over a billion times.
