'97 Ranger - 3.0L - 5 Speed - 95,260 miles
Just recently bought my truck, love it so far, mostly... After I've been driving it a few days, I've noticed a couple smaller issues that could be the cause of a bigger issue?
Truck runs down the road, easily. Idles fine, for the most part. Shifts fine, for the most part.
1. If I leave it idling for about 3-4 minutes, it feels as if it jumps, or is misfiring every once in a while.
2. When taking off in first gear, the truck will almost stop in it's tracks. This has only happened TWICE since I've had it, but being I've had it for only 4 days, that's a fairly concerning amount.
3. Second gear will grind if I try to shift quickly, from higher RPMs.
4. If I'm trying to gain speed quickly, like merging on to the highway, the truck seems to cut out for a millisecond, then back at it, then cut out again. Almost like it's losing fuel. Volume and fuel pressure test fine.
5. Fuel gauge randomly stopped. Has 1/4 tank in it now, and started to register it, while I was driving, then cut out completely again. Tested/bypassed the anti-slosh module, or whatever it's called, and didn't change anything.
