superrunner and Tie rod replacement
crawlin91
OTOTM Winner
Solid Axle Swap
Crawlorado
Ive got the truck lifted and a used superrunner steering system on it. The tie rod ends are shot, so are the ones I took off the original steering. I searched and didnt find any info on this topic but
Will changing them screw up an alignment?
Anyone recommend using specific brand?
How do I make sure I install them correctly?:icon_confused:
you can use stock Ranger TRE's to replace the Superunner TRE's.
If you have already had an alignment, replace the TRE's with the truck on it's own weight; that will eliminate the tires from being moved. It will force you to put the ends back to where they were before.
