SuperLift Radius arm Shock issue?
Dugan
New Castle, DE
Has anyone ever had an issue with their Superlift arms? I believe to have the older style, C-channel arms. The shock mounts on the outsides are the arms seem to point downwards causing the body of my shocks to have to be slightly dented in to fit. Also as the travel of the arm swings downward more force is put into the shock body. Im afraid that when I do my f250 shock mounts the piston of th shock will be bent, because the arm will contact it. (Will be mounting the shocks upside down i guess to clearance better)
Its hard to tell but they were hitting and I believe the arms were at full droop at this point.
You can see more pics on the first page of my build. Also, why would the pass side arm drop a lot more then the drivers side arm? Driveshaft holding it up??
