- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
As the title suggests.
We have our 95' explorer. Manual 5 speed.
Traced the shifting issues mostly due to clutch fluid being contaminated.
What seems to been happening is a lot of water was introduced into the system. After everything got 'hot' the clutch was a bear to get into 1st, 2nd and reverse would actually grind gears. So much to the point we shut the truck off, put it into reverse, and started-backed up where needed.
I bleed out the clutch about 3-4 shots just like bleeding brakes. What came out was wicked HOT fluid with almost a milky look to it.
We made sure the master didn't run dry, but given the size of that slave, I'm pretty sure there's still a lot more yuck fluid left into the mix. I know water in a brake system can and will boil due to the temps. I feel that is what is happening due to the amount of HOT fluid that we bleed out of it. Sense we have bleed it out, it goes into 1st and 2nd a tad stiff..but it's manageable. Reverse? No issues anymore. You do need to mash the pedal completely to the floor, but it no longer grinds. Slips right into gear no problem.
Fairly sure there's a lot more that should be flushed out. Other then bleeding it several more times (and slowly getting all that crud out) Is there any quick way of doing this in one sitting?
Thanks!
S-
Thanks!
S-
