chudykGT
I have a 2008 Ranger Sport 4x4, 3.73 8.8 locked with a lockright. Lately it has been -20 Celsius or colder where I live. I have had a few times where truck is cold and I take a corner and lose power.
I hear a noise that sounds like gears slipping, and at first thought I had the locker not engage because I had just made a turn and pressed the throttle and due to thick cold diff fluid, the locker didn't engage. Then bang, Im going again.
However, another day I had the same thing happen, and came to a creeping stop as regardless of throttle the noise stayed and it sounded like the transfercase, not the diff, was the source of the noise. I braked to bring the rpm down and tried to shift into 4x4 hi (from 2hi), and the t-case just made a grinding groaning noise. I then clicked it back to 2 wheel drive and even just tapping the throttle made the "gear slipping" noise.
So now I was stuck with no power to either drive shaft. I called a buddy for a tow, and at that point, my neighbor, a jeep fan, drove by driving a sport trac he just fixed, and mocked me for the blue oval. He offered to tow me after I explained the problem to him, and we put it back in gear so I could show him what it was doing, and boom, I had rwd again. I tried 4hi and it worked too.
I checked the tranny fluid, and it is fine. I noticed it was damp around the rear tcase output seal, but not wet, and there has been no puddles where it is parked. It spends most of its time parked, as I am a heating technician, and work over time every day because its so ****ing cold right now. So if it was a big leak, the week at a time it spends parked there should be a puddle.
Today it happened again briefly as I made a turn under load and the noise and power loss came back. I stopped, put it in neutral, then back in gear and everything was fine.
Everytime this has happened it has been colder than minus 20 Celsius.
Any ideas where to start looking? I am in 2wd when this happens, and the t-case engages 4hi and 4lo normally other than the one incident.
