- Feb 28, 2022
- Tallmadge, OH
- Automatic
I was leaving o'reilly's earlier and noticed my oil pressure was almost none so I immediately pulled back into the parking lot and shut it off. It was fine while I was driving before I went to o'reilly's. It still sounded like it ran how it normally does in the short time I had it running with almost no oil pressure and still started fine. No noises before this happened or nothing really. I noticed the past 2ish days I've heard a pretty infrequent pinging sound (imagine the sound when a pebble hits the floor of your car). No idea if that has anything to do with this, but I figured I'd mention it. When I finally got it towed home, I saw its dumping a good bit of trans fluid onto my garage floor, but almost no oil leaking at all (I've had a very small valve cover gasket leak for months). I checked the oil level 3 days ago and it was good, checked it again after getting home to double check, sure enough its still at a good level. I don't know how old the oil in it is, but when I got the truck 8 months ago, it looked like brand new oil and still looks pretty good. I've only driven 1.5k-ish miles due to a project, so haven't changed it yet (planned on changing it very soon). I doubt it would be the oil in it though due to the drop being so sudden. The oil gauge is barely above off when it was running, so its not like the gauge was on complete 0.
Basically, I'm just asking if anyone has suggestions. I think it could be the oil pump that failed just because of how quick it happened. Doubt its ever been replaced in the 36 years it's been on the truck.
