kenwheeler
I'm having problems getting the clutch bled. I have a very spongy pedal. Clutch won't allow me to put the vehicle in gear when running. When I gravity bleed, the fluid just trickles out the hose into the recovery jar. When I hold the pedal to the floor and open the bleeder, fluid squirts out with what seems like some strong pressure. After I release the pedal, its back to spongy.
I also tried the 5 pump quick release wait 2 seconds between each pump procedure, back to spongy. When I quick release the pedal, I hear a sucking noise in the pedal master cylinder is this normal?
